# IntelliJ IDE
# Prerequisities
- git, Maven, IntelliJ and Java 11 are installed
# Install openHAB distribution
./start_debug.shinstead of./start.shin step 4)
This article refers to the directory where you installed the distribution as <DISTRO_DIR>.
# Build the addons repository
Fork and clone the openhab addons repository (opens new window) into a new directory (Reference
<ADDON_DIR>from now on for this arcticle) withgit clone https://github.com/<yourgitusername>/openhab-addons(replace git user name accordingly)Open IntelliJ and create a new project from existing sources (File | New | Project from existing sources) and pick
<ADDON_DIR>/pom.xmlIntelliJ will start importing, indexing and building, it will take while, wait until finished (see status bar)
Use Maven to clean & install the addons project
- mvn clean install in the root of
<ADDON_DIR>using commandline Maven (or IntelliJ Maven view) - some of the addons might fail to build - if it's not the one, you're interested in that should not bother you
# Debug your addon
Copy the addon JAR to Openhab distribution created before
The running instance of the openhab distribution should pick up your new addon & start it
- you can type
log:tailin the openhab console to stream the openhab logs
- you can type
Create a Remote Debug runtime configuration in IntelliJ:
- open menu Run | Edit configurations
- click OK
