# Installation of Add-ons
# Through UI
Log into your admin account (if not already done).
Navigate to Settings and have a look for the add-ons section.
Search for the desired add-on in the categories and press install.
# Through Configuration Files
For this installation option you need to know the id of the desired add-on, e.g., network or mqtt.
feature:list | grep ^openhab
openhab-binding-mqtt | 3.0.0.M5 | | Started | openhab-addons-3.0.0.M5 | MQTT Binding
openhab-binding-netatmo | 3.0.0.M5 | | Started | openhab-addons-3.0.0.M5 | Netatmo Binding
openhab-binding-onewire | 3.0.0.M5 | | Uninstalled | openhab-addons-3.0.0.M5 | OneWire Binding
openhab-binding-network | 3.0.0.M5 | | Uninstalled | openhab-addons-3.0.0.M5 | Network Binding
Another way to find the correct id is to look at the URL of the add-on documentation page.
For example the url for the Network Binding documentation is
In this case, the id would be "network".
With this information we can now edit the addons.cfg file in the $OPENHAB_CONF/services folder on the machine you are running openHAB on.
The path depends on your installation.
You can find out the correct locations on the corresponding documentation pages, e.g. Linux or Windows.
ui = basic,habpanel
action = pushover
binding = astro
transformation = jsonpath
persistence = influxdb
binding = astro,network
Attention
This option is adressed to advanced users.
Installing add-on's with a .jarfile can lead to problems, because add-on dependencies may not be installed.
Please make sure to use this option only in special cases (like add-on testing for an upcoming version) or when you know what you are doing.
For this installation option you need a bundles .jar file.
One way of retrieving those files is mentioned above in the openHAB console part.
Place the .jar file in the addons folder on the machine you are running openHAB on.
As described already for the addons.cfg option, the path depends on your installation.
Place the .jar file in the folder Additional add-on files as described in File Locations (Linux, Windows or macOS).
# Through the openHAB console
Add-ons (also known as bundles) can be also installed and updated via the openHAB console. A detailed description can be found at Installing or Updating Bundles.
