# Persistence
# Persistence Blocks
More about that topic can be viewed at Using Persistence data (opens new window)
- average: gets the average value of the State of a persisted Item since a certain point in time. This method uses a time-weighted average calculation
- delta: gets the difference in value of the State of a given Item since a certain point in time
- deviation: gets the standard deviation of the state of the given Item since a certain point in time
- variance: gets the variance of the state of the given item since a certain point in time
- evolution rate: gets the evolution rate of the state of the given Item in percent since a certain point in time (may be positive or negative)
- minimum: gets the minimum value of the State of the given Item since a certain point in time
- maximum: gets the maximum value of the State of the given Item since a certain point in time
- maximum: gets the sum of the State of the given Item since a certain point in time
In the case of the following two functions the block changes its appearence by replacing the time with an option to chose if the equal value should be skipped or not:
- previous state value: Gets the previous state with option to skip to different value as current
- previous state value time: Gets the time when previous state last occurred with option to skip to different value as current
The skip option set to true allows to search for first state that is different from the current state.
Important: This option is not supported by all persistence databases and may throw an error in that case (for example the standard rrd4j does not support it while influxdb does support it).
Notes: in case no or 0 values are retrieved, make sure that the item in question is actually persisted.
Previous State Example
Function: checks if an item was updated or changed since a certain point in time
Type: boolean true or false
