# Item & Things
Items and Things are the major entities of openHAB (opens new window) to control and monitor the home. These can be accessed via the "Items & Things" section of the Blockly Toolbox.
# Item and Thing Blocks
See a video introduction at Working with Items (opens new window)
# Item
never use this block alone as it only returns the items name which alone does not make sense. Instead use the get-Item-Block below.
- Clicking 'MyItem' displays a list of Items to pick from
- Technically this block returns the name of the item as a String.
- As a result, this block can be used wherever the item name is required as a String.
- Learn more about items here (opens new window)
# Get Item
- Clicking 'MyItem' displays a list of Items to pick from.
- Technically this block returns an item object, to be used to retrieve specific attributes using other blocks (see below).
- As this block does not return a String it cannot be directly attached to a log-block, as demonstrated below.
- Tip: Often you do want to retrieve the state, hence use the "Get State of Item"-block below
- The block returns the item itself. If you want to log the items information you can assign it to a variable first and the log the variable.
# Get State of Item
- Returns the state (opens new window) of an item like ON/OFF, the temperature value etc.
it is recommended in this case to assign this to a variable and use the "String-Append-Text" with an empty "" to convert it into a String for further processing.
See the Item-State documentation (opens new window) for more information
# Get Members of Group
- returns a collection of items which should be used with a for-each-block to loop over the items
- it can be attached to a log-block which would list all items in that block in the form a string representation as follows
- Alternatively you can use the item block var the loop variable to send a command to the items of the group
# Get Items with Tag
Function: Gets all items with the given tags which you can iterate over via a loop
- returns a collection of items which have the given tags
- multiple tags can be provided which then need to be separared with a comma
- if multiple tags are given, the item must have all of the tags ("and"-condition)
If you need an item that has one of multiple tags, then you need to use one block of each and then use the "concatenate list block" (opens new window) to combine the results.
# Get particular attributes of an item
- name: String
- label: String
- state: State
- category: String
- tag: Array, e.g.
[plannedTimes]
- groups: Array, e.g.
[plannedTimes, timers]
- type: String
Depending on your openHAB version (pre-3.3) this block may not connect as expected. As a workaround attach the block to a variable first, and use the variable in the rest of the script.
Special handling for Arrays
- they cannot be connected to a block that expects a String (e.g. log-block)
- they must be handled using a for-loop as follows
# Send Command
- value: any state value that is allowed for that item, eg. ON or OFF for a switch.
- Clicking 'MyItem' displays a list of Items to pick one item from
For the difference between send command and post update see "Manipulating States" (opens new window) and "Event Bus Actions" (opens new window).
More about that topic can be viewed at Sending Commands (opens new window)
Item-block examples
Example 1:
- Check if MainSwitch is ON.
- If ON, send ON command to livingroomLight item.
Example 2:
- Get the state of MainSwitch and
- Immediately send it as a command to F2_Office_Main_Light
Ensure that the receiving item can handle the state of the 'sending' item.
# Thing
- Clicking 'MyThing' displays a list of Things to pick from
- Technically this block returns the thingUid of the thing as a String
- Learn more about things (opens new window) or thing-concepts (opens new window)
will write the following into the log
# Get Thing Status
Function: Gets a Thing Status for use in other Thing related functions
- Clicking 'MyThing' displays a list of Things to pick from.
- Technically this block returns a ThingStatus (opens new window) - a String with one of the following statuses
- UNINITIALIZED
- INITIALIZING
- UNKNOWN
- ONLINE
- OFFLINE
- REMOVING
- REMOVED
