# HomeKit Add-on
- Switchable
- Outlet
- Fan
- Thermostat
- Heater / Cooler
- Lock
- Security System
- Garage Door Opener
- Motorized Door
- Motorized Window
- Window Covering/Blinds
- Slat
- Valve
- Faucet / Shower
- Speaker
- SmartSpeaker
- Microphone
- Air Quality Sensor
- Contact Sensor
- Leak Sensor
- Motion Sensor
- Occupancy Sensor
- Smoke Sensor
- Temperature Sensor
- Humidity Sensor
- Light Sensor
- Carbon Dioxide Sensor
- Carbon Monoxide Sensor
- Battery
- Filter Maintenance
# Quick start
install homekit addon via UI
open home app on your iPhone or iPad
create new home
add accessory
click "Add Anyway"
follow the instruction of the home app wizard
Add metadata to more items or fine-tune your configuration using further settings
# Global Configuration
You can define HomeKit settings either via mainUI or via $OPENHAB_CONF/services/homekit.cfg.
Other settings, such as using Fahrenheit temperatures, customizing the thermostat heat/cool/auto modes, and specifying the interface to advertise the HomeKit bridge are also illustrated in the following sample:
org.openhab.homekit:port=9123
org.openhab.homekit:thermostatTargetModeCool=CoolOn
org.openhab.homekit:thermostatTargetModeHeat=HeatOn
org.openhab.homekit:thermostatTargetModeAuto=Auto
org.openhab.homekit:thermostatTargetModeOff=Off
org.openhab.homekit:instances=1
org.openhab.homekit:useDummyAccessories=false
Some settings are only visible in UI if the checkbox "Show advanced" is activated.
# Overview of all settings
| networkInterface | IP address or domain name under which the HomeKit bridge can be reached. If no value is configured, the add-on uses the primary IP address configured for openHAB. If unsure, keep it empty | (none) |
| useOHmDNS | mDNS service is used to advertise openHAB as HomeKit bridge in the network so that HomeKit clients can find it. openHAB has already mDNS service running. This option defines whether the mDNS service of openHAB or a separate service should be used. | false |
| blockUserDeletion | Blocks HomeKit user deletion in openHAB and as result unpairing of devices. If you experience an issue with accessories becoming non-responsive after some time, try to enable this setting. You can also enable this setting if your HomeKit setup is done and you will not re-pair ios devices. | false |
| useFahrenheitTemperature | Set to true to use Fahrenheit degrees, or false to use Celsius degrees. Note if an item has a QuantityType as its state, this configuration is ignored and it's always converted properly. | false |
| thermostatTargetModeCool | Word used for activating the cooling mode of the device (if applicable). It can be overwritten at item level. | CoolOn |
| thermostatTargetModeHeat | Word used for activating the heating mode of the device (if applicable). It can be overwritten at item level. | HeatOn |
| thermostatTargetModeAuto | Word used for activating the automatic mode of the device (if applicable). It can be overwritten at item level. | Auto |
| thermostatTargetModeOff | Word used to set the thermostat mode of the device to off (if applicable). It can be overwritten at item level. | Off |
| instances | Defines how many bridges to expose. Necessary if you have more than 149 accessories. Accessories must be assigned to additional instances via metadata. Additional bridges will use incrementing port numbers. | 1 |
| useDummyAccessories | When an accessory is missing, substitute a dummy in its place instead of removing it. See Dummy Accessories. | false |
If the first word of the item name match the room name in home app, home app will hide it. E.g. item with the name "Kitchen Light" will be shown in "Kitchen" room as "Light". This is recommended naming convention for HomeKit items and rooms.
# UI based Configuration
select desired item in mainUI
click on "Add Metadata"
click on "Save"
# Textual configuration
You can link one openHAB item to one or more HomeKit accessory, e.g.
The tag can be:
You can use openHAB group to manage state of multiple items. (see Group items (opens new window)) In this case, you can assign HomeKit accessory type to the group and to the group items Following example defines 3 HomeKit accessories of type Lighting:
- "Light 1" and "Light 2" as independent lights
- "Light Group" that controls "Light 1" and "Light 2" as group
Switch light1 "Light 1" (gLight) {homekit="Lighting.OnState"}
Switch light2 "Light 2" (gLight) {homekit="Lighting.OnState"}
# Dummy Accessories
OpenHAB is a highly dynamic system, and prone to occasional misconfigurations where items can't be loaded for various reasons, especially if you're using something besides the UI to manage your items.
This is a problem for Homekit because if the bridge makes a connection, but accessories are missing, then the Homekit database will simply remove that accessory.
When the accessory does come back (i.e. because you corrected a syntax error in an .items file, or OpenHAB completes booting), all customization of that accessory will be lost - the room assignment, customized name, custom icon, status/home screen/favorite preferences, etc.
In order to work around this, the Homekit addon can create dummy accessories for any accessory it has previously published to Homekit.
To enable this behavior, turn on the useDummyAccessories setting.
OpenHAB will then simply present a non-interactive accessory for any that are missing.
The OpenHAB log will also contain information whenever a dummy accessory is created.
If the item backing the accessory is later re-created, everything will sync back up and nothing will be lost.
You can also run the console command openhab:homekit listDummyAccessories to see which items are missing.
Apple devices may or may not show "Not Responding" for some or all accessories when there are dummy accessories, since they will no longer be backed by actual items with state.
It's recommended that you resolve this state as soon as possible, since Homekit may decide your entire bridge is being uncooperative, and remove everything itself.
If you actually meant to remove an item, you will need to purge the dummy items from the database so that they'll disappear from the Home app altogether.
In order to do so, run the console command openhab:homekit pruneDummyAccessories.
Alternatively, disabling, saving, and then re-enabling useDummyAccessories in the addon settings will have the same effect.
# Dimmers
The way HomeKit handles dimmer devices can be different to the actual dimmers' way of working. HomeKit home app sends following commands/update:
- On brightness change home app sends "ON" event along with target brightness, e.g. "Brightness = 50%" + "State = ON".
- On "ON" event home app sends "ON" along with brightness 100%, i.e. "Brightness = 100%" + "State = ON"
- On "OFF" event home app sends "OFF" without brightness information.
# Color Temperature
Color temperature can be represented various ways in OpenHAB. Given the base bulb configured like this:
Group gLight "CCT Light" { homekit="Lighting" }
Switch light_switch (gLight) { homekit="Lighting.OnState" }
The color temperature might be configured in any of these ways:
// Number item presumed in mireds
Number light_temp (gLight) { homekit="Lighting.ColorTemperature" }
// Number item explicitly in mireds
Number:Temperature light_temp "Temp [%.0f mired]" { homekit="Lighting.ColorTemperature" }
// Number item explicitly in Kelvin
Number:Temperature light_temp "Temp [%.0f K]" { homekit="Lighting.ColorTemperature" }
// Dimmer item, with allowed range given in mireds
Dimmer light_temp { homekit="Lighting.ColorTemperature"[ minValue=50, maxValue=400 ]}
// Dimmer item, with allowed range given in Kelvin
Dimmer light_temp { homekit="Lighting.ColorTemperature"[ minValue="2700 K", maxValue="5000 K" ]}
// Dimmer item, where 0% represents "warm" instead of "cool" (i.e. if it's backed by a channel
// that's ultimately interpreting the value in Kelvin instead of mireds)
Dimmer light_temp { homekit="Lighting.ColorTemperature"[ minValue="2700 K", maxValue="5000 K", inverted=true ]}
- OPEN if position is 0%,
- CLOSED if position is 100%.
- OPEN if position 100%
- CLOSED if position is 0%
Therefore, HomeKit integration inverts by default the values between openHAB and HomeKit, e.g. if openHAB current position is 30% then it will send 70% to HomeKit app. In case you need to disable this logic you can do it with configuration parameter inverted=false, e.g.
Rollershutter window_covering "Window Rollershutter" {homekit = "WindowCovering" [inverted=false]}
Rollershutter window "Window" {homekit = "Window" [inverted=false]}
Rollershutter door "Door" {homekit = "Door" [inverted=false]}
HomeKit home app never sends "STOP" but only the target position. If you add configuration parameter "stop=true", openHAB will emulate stop and send "STOP" command to rollershutter item if you click on the blind icon in the iOS home app while the blind is moving.
Rollershutter window_covering "Window Rollershutter" {homekit = "WindowCovering" [stop=true]}
Some blinds devices do support "STOP" command but would stop if they receive UP/DOWN while moving om the same direction. In order to support such devices add "stopSameDirection" parameter.
Rollershutter window_covering "Window Rollershutter" {homekit = "WindowCovering" [stop=true, stopSameDirection=true]}
Rollershutter window_covering "Blind" (gBlind) {homekit = "WindowCovering"}
Dimmer window_covering_htilt "Blind horizontal tilt" (gBlind) {homekit = "WindowCovering.CurrentHorizontalTiltAngle, WindowCovering.TargetHorizontalTiltAngle"}
Dimmer window_covering_vtilt "Blind vertical tilt" (gBlind) {homekit = "WindowCovering.CurrentVerticalTiltAngle, WindowCovering.TargetVerticalTiltAngle"}
# Thermostat
- CurrentTemperature
- TargetTemperature
- CurrentHeatingCoolingMode
- TargetHeatingCoolingMode
Number thermostat_current_temp "Thermostat Current Temp [%.1f °C]" (gThermostat) {homekit = "CurrentTemperature"}
Number thermostat_target_temp "Thermostat Target Temp [%.1f °C]" (gThermostat) {homekit = "TargetTemperature"}
In addition, thermostat can have thresholds for cooling and heating modes. Example with thresholds:
Number thermostat_target_temp "Thermostat Target Temp[%.1f °C]" (gThermostat) {homekit = "TargetTemperature"}
Number thermostat_cool_thrs "Thermostat Cool Threshold Temp [%.1f °C]" (gThermostat) {homekit = "CoolingThresholdTemperature"}
Number thermostat_heat_thrs "Thermostat Heat Threshold Temp [%.1f °C]" (gThermostat) {homekit = "HeatingThresholdTemperature"}
# Min / max temperatures
- current temperature: min value = 0 °C, max value = 100 °C
- target temperature: min value = 10 °C, max value = 38 °C
Number thermostat_current_temp "Thermostat Current Temp [%.1f °C]" (gThermostat) {homekit = "CurrentTemperature" [minValue=5, maxValue=30]}
Number thermostat_target_temp "Thermostat Target Temp[%.1f °C]" (gThermostat) {homekit = "TargetTemperature" [minValue=10.5, maxValue=27]}
# Thermostat modes
These modes are mapped to string values of openHAB items using either global configuration (see [Global Configuration](#Global Configuration)) or configuration at item level. e.g. if your current mode item can have following values: "OFF", "HEATING", "COOLING" then you need following mapping at item level
You can provide mapping for target mode in similar way.
The custom mapping at item level can be also used to reduce number of modes shown in home app. The modes can be only reduced, but not added, i.e. it is not possible to add new custom mode to HomeKit thermostat.
# Valve
Upon valve activation in home app, home app starts to count down from the "duration" to "0" without contacting the server. Home app also does not trigger any action if it remaining duration get 0. It is up to valve to have an own timer and stop valve once the timer is over. Some valves have such timer, e.g. pretty common for sprinklers. In case the valve has no timer capability, openHAB can take care on this - start an internal timer and send "Off" command to the valve once the timer is over.
- valve with timer:
Group gValve "Valve Group" {homekit="Valve" [homekitValveType="Irrigation", homekitTimer="true"]}
# Sensors
| BatteryLowStatus | Switch, Contact, Number | Accessory battery status. "ON"/"OPEN" indicates that the battery level of the accessory is low. Value should return to "OFF"/"CLOSED" when the battery charges to a level that's above the low threshold. Alternatively, you can give a Number item that's the battery level, and if it's lower than the lowThreshold configuration, it will report low. |
Switch and Contact items support inversion of the state mapping, e.g. by default the openHAB switch state "ON" is mapped to HomeKit contact sensor state "Open", and "OFF" to "Closed". The configuration "inverted=true" inverts this mapping, so that "ON" will be mapped to "Closed" and "OFF" to "Open".
Number temperature_sensor "Temperature Sensor [%.1f °C]" {homekit="TemperatureSensor"}
Contact contact_sensor "Contact Sensor" {homekit="ContactSensor" [inverted=true]}
Switch leaksensor_active "Leak Sensor Active" (gLeakSensor) {homekit="ActiveStatus" [inverted=true]}
Switch motionsensor_bat "Motion Sensor Battery" (gMotionSensor) {homekit="BatteryLowStatus" [inverted=true]}
or using UI
# Complex accessory
Multiple HomeKit accessories can be combined to one accessory in order to group several functions provided by one or multiple physical devices.
For example, ceiling fans often include lighting functionality. Such fans can be modeled as:
two separate HomeKit accessories - fan and light.
iOS home app would show them as two tiles that can be controlled directly from home screen.
one complex accessory - fan with light.
iOS home app would show them as one tile that opens view with two controls
The provided functionality is in both cases identical.
In order to combine multiple accessories to one HomeKit accessory you need:
- add corresponding openHAB items to one openHAB group
- configure HomeKit metadata of both HomeKit accessories at that group.
e.g. configuration for a fan with light would look as follows
Group FanWithLight "Fan with Light" {homekit = "Fan,Lighting"}
Switch FanActiveStatus "Fan Active Status" (FanWithLight) {homekit = "Fan.ActiveStatus"}
Number FanRotationSpeed "Fan Rotation Speed" (FanWithLight) {homekit = "Fan.RotationSpeed"}
Switch Light "Light" (FanWithLight) {homekit = "Lighting.OnState"}
or in mainUI
iOS home app uses by default the type of the first accessory on the list for the tile on home screen. e.g. an accessory defined as homekit = "Fan,Light" will be shown as a fan and an accessory defined as homekit = "Light,Fan" as a light in iOS home app.
if you want to change the tile you can either change the order of types in homekit metadata or add "primary=
Group FanWithLight "Fan with Light" {homekit = "Light,Fan" [primary = "Fan"]}
Similarly, you can create a sensor with battery
However, home app does not support changing of tiles for already added accessory. If you want to change the tile after the accessory was added, you need either to rename the group, if you use textual item configuration, or to delete and to create a new group with a different name, if you use UI for configuration.
You can combine more than two accessories as well as accessories linked to different physical devices. You can also do unusually combinations, e.g. you can combine temperature sensor with blinds and light. It will be represented by home app as follows
# Limitations
Currently, it is not possible to combine multiple accessories of the same type, e.g. 2 lights. Support for this is planned for the future release of openHAB HomeKit binding.
# Supported accessory type
| Accessory Tag | Mandatory Characteristics | Optional Characteristics | Supported OH items | Description |
| AirQualitySensor | Air Quality Sensor which can measure different parameters | |||
| AirQuality | String | Air quality state, possible values (UNKNOWN,EXCELLENT,GOOD,FAIR,INFERIOR,POOR). Custom mapping can be defined at item level, e.g. [EXCELLENT="BEST", POOR="BAD"] | ||
| OzoneDensity | Number | Ozone density in micrograms/m3, max 1000 | ||
| NitrogenDioxideDensity | Number | NO2 density in micrograms/m3, max 1000 | ||
| SulphurDioxideDensity | Number | SO2 density in micrograms/m3, max 1000 | ||
| PM25Density | Number | PM2.5 micrometer particulate density in micrograms/m3, max 1000 | ||
| PM10Density | Number | PM10 micrometer particulate density in micrograms/m3, max 1000 | ||
| VOCDensity | Number | VOC Density in micrograms/m3, default max 1000, supported configuration: minValue, maxValue, step. | ||
| Name | String | Name of the sensor | ||
| ActiveStatus | Switch, Contact | Working status | ||
| FaultStatus | Switch, Contact | Fault status | ||
| TamperedStatus | Switch, Contact | Tampered status | ||
| BatteryLowStatus | Switch, Contact, Number | Battery status | ||
| LeakSensor | Leak Sensor | |||
| LeakDetectedState | Switch, Contact, Dimmer | Leak sensor state (ON=Leak Detected, OFF=no leak) | ||
| MotionSensor | Motion Sensor | |||
| MotionDetectedState | Switch, Contact, Dimmer | Motion sensor state (ON=motion detected, OFF=no motion) | ||
| OccupancySensor | Occupancy Sensor | |||
| OccupancyDetectedState | Switch, Contact, Dimmer | Occupancy sensor state (ON=occupied, OFF=not occupied) | ||
| ContactSensor | Contact Sensor, An accessory with on/off state that can be viewed in HomeKit but not changed such as a contact sensor for a door or window | |||
| ContactSensorState | Switch, Contact, Dimmer | Contact sensor state (ON=open, OFF=closed) | ||
| SmokeSensor | Smoke Sensor | |||
| SmokeDetectedState | Switch, Contact, Dimmer | Smoke sensor state (ON=smoke detected, OFF=no smoke) | ||
| LightSensor | Light sensor | |||
| LightLevel | Number | Light level in lux | ||
| HumiditySensor | Relative Humidity Sensor providing read-only values | |||
| RelativeHumidity | Number | Relative humidity in % between 0 and 100. additional configuration homekitMultiplicator = | ||
| TemperatureSensor | Temperature sensor | |||
| CurrentTemperature | Number | current temperature. supported configuration: minValue, maxValue, step. | ||
| CarbonDioxideSensor | Carbon Dioxide Sensor | |||
| CarbonDioxideDetectedState | Switch, Contact, Dimmer | carbon dioxide sensor state (ON- abnormal level of carbon dioxide detected, OFF - level is normal) | ||
| CarbonDioxideLevel | Number | Carbon dioxide level in ppm, max 100000 | ||
| CarbonDioxidePeakLevel | Number | highest detected level (ppm) of carbon dioxide detected by a sensor, max 100000 | ||
| CarbonMonoxideSensor | Carbon monoxide Sensor | |||
| CarbonMonoxideDetectedState | Switch, Contact, Dimmer | Carbon monoxide sensor state (ON- abnormal level of carbon monoxide detected, OFF - level is normal) | ||
| CarbonMonoxideLevel | Number | Carbon monoxide level in ppm, max 100 | ||
| CarbonMonoxidePeakLevel | Number | highest detected level (ppm) of carbon monoxide detected by a sensor, max 100 | ||
| Door | Motorized door. One Rollershutter item covers all mandatory characteristics. see examples below. | |||
| CurrentPosition | Rollershutter, Dimmer, Number | Current position of motorized door | ||
| TargetPosition | Rollershutter, Dimmer, Number | Target position of motorized door | ||
| PositionState | Rollershutter, String | Position state. Supported states: DECREASING, INCREASING, STOPPED. Mapping can be redefined at item level, e.g. [DECREASING="Down", INCREASING="Up"]. If no state provided, "STOPPED" is used. | ||
| Name | String | Name of the motorized door | ||
| HoldPosition | Switch | Motorized door should stop at its current position. A value of ON must hold the state of the accessory. A value of OFF should be ignored. | ||
| ObstructionStatus | Switch, Contact, Dimmer | Current status of obstruction sensor. ON-obstruction detected, OFF - no obstruction | ||
| Window | Motorized window. One Rollershutter item covers all mandatory characteristics. see examples below. | |||
| CurrentPosition | Rollershutter, Dimmer, Number | Current position of motorized window | ||
| TargetPosition | Rollershutter, Dimmer, Number | Target position of motorized window | ||
| Name | String | Name of the motorized window | ||
| WindowCovering | Window covering / blinds. One Rollershutter item covers all mandatory characteristics. see examples below. | |||
| CurrentPosition | Rollershutter, Dimmer, Number | Current position of window covering | ||
| TargetPosition | Rollershutter, Dimmer, Number | Target position of window covering | ||
| PositionState | Rollershutter, String | Currently only "STOPPED" is supported. | ||
| Name | String | Name of the windows covering | ||
| HoldPosition | Switch | Window covering should stop at its current position. A value of ON must hold the state of the accessory. A value of OFF should be ignored. | ||
| CurrentHorizontalTiltAngle | Number, Dimmer | Number Item = current angle of horizontal slats. values -90 to 90. A value of 0 indicates that the slats are rotated to a fully open position. A value of -90 indicates that the slats are rotated all the way in a direction where the user-facing edge is higher than the window-facing edge. Dimmer Item = the percentage of openness (0%-100%) | ||
| TargetHorizontalTiltAngle | Number, Dimmer | Number Item = target angle of horizontal slats (-90 to +90). Dimmer Item = the percentage of openness (0%-100%) | ||
| CurrentVerticalTiltAngle | Number, Dimmer | Number Item = current angle of vertical slats (-90 to +90) . Dimmer Item = the percentage of openness (0%-100%) | ||
| TargetVerticalTiltAngle | Number, Dimmer | Number Item = target angle of vertical slats. Dimmer Item = the percentage of openness (0%-100%) | ||
| Slat | Slat which tilts on a vertical or a horizontal axis. Configuration "type:horizontal" or "type:vertical" | |||
| CurrentSlatState | String | Current slat state. possible values (FIXED,SWINGING,JAMMED). Custom mapping can be defined at item level, e.g. [JAMMED="JAM", FIXED="FIX"] | ||
| Name | String | Name of the slat | ||
| SwingMode | Number, Switch | Swing mode. values: 0/OFF=SWING DISABLED, 1/ON=SWING ENABLED | ||
| CurrentTiltAngle | Number, Dimmer | Number Item = current angle of slats. values -90 to 90. A value of 0 indicates that the slats are rotated to a fully open position. Dimmer Item = the percentage of openness (0%-100%) | ||
| TargetTiltAngle | Number, Dimmer | Number Item = target angle of slats (-90 to +90). Dimmer Item = the percentage of openness (0%-100%) | ||
| Switchable | An accessory that can be turned off and on. While similar to a lightbulb, this will be presented differently in the Siri grammar and iOS apps | |||
| OnState | Switch, Dimmer | State of the switch - ON/OFF | ||
| Name | String | Name of the switch | ||
| Outlet | An accessory that can be turned off and on. While similar to a lightbulb, this will be presented differently in the Siri grammar and iOS apps | |||
| OnState | Switch, Dimmer | State of the outlet - ON/OFF | ||
| InUseStatus | Switch, Contact, Dimmer | Indicates whether the outlet has an appliance e.g., a floor lamp, physically plugged in. This characteristic is set to True even if the plugged-in appliance is off. | ||
| Lighting | A lightbulb, can have further optional parameters for brightness, hue, etc | |||
| OnState | Switch | State of the light - ON/OFF | ||
| Name | String | Name of the light | ||
| Hue | Dimmer, Color | Hue | ||
| Saturation | Dimmer, Color | Saturation in % (1-100) | ||
| Brightness | Dimmer, Color | Brightness in % (1-100). See "Usage of dimmer modes" for configuration details. | ||
| ColorTemperature | Number, Dimmer | Color temperature. If the item is a Number with no units, it is represented in mireds. The default value range is from 50 to 400 (2500 K to 20,000 K). If the item is a Dimmer, it will be transformed linearly to mireds. Color temperature should not be used in combination with hue, saturation and brightness. It supports following configuration parameters: minValue, maxValue, inverted | ||
| Fan | Fan | |||
| ActiveStatus | Switch, Dimmer | Accessory current working status. A value of "ON"/"OPEN" indicates that the accessory is active and is functioning without any errors. | ||
| CurrentFanState | Number | Current fan state. values: 0=INACTIVE, 1=IDLE, 2=BLOWING AIR | ||
| TargetFanState | Number, Switch | Target fan state. values: 0/OFF=MANUAL, 1/ON=AUTO. Flag [inverted=true] swaps the default mapping | ||
| RotationDirection | Number, Switch | Rotation direction. values: 0/OFF=CLOCKWISE, 1/ON=COUNTER CLOCKWISE. Flag [inverted=true] swaps the default mapping | ||
| RotationSpeed | Number, Dimmer | Fan rotation speed in % (1-100) | ||
| SwingMode | Number, Switch | Swing mode. values: 0/OFF=SWING DISABLED, 1/ON=SWING ENABLED. Flag [inverted=true] swaps the default mapping | ||
| LockControl | Number, Switch | Status of physical control lock. values: 0/OFF=CONTROL LOCK DISABLED, 1/ON=CONTROL LOCK ENABLED.Flag [inverted=true] swaps the default mapping | ||
| BasicFan | Fan. A BasicFan is a subset of Fan, but the Home app allows you to customize the icon of the accessory to show a ceiling fan. | |||
| OnState | Switch, Dimmer | Accessory current working status. A value of "ON"/"OPEN" indicates that the accessory is active and is functioning without any errors. | ||
| Thermostat | A thermostat requires all mandatory characteristics defined below | |||
| CurrentTemperature | Number | Current temperature. supported configuration: minValue, maxValue, step | ||
| TargetTemperature | Number | Target temperature. supported configuration: minValue, maxValue, step | ||
| CurrentHeatingCoolingMode | String | Current heating cooling mode (OFF, AUTO, HEAT, COOL). for mapping see homekit settings above. | ||
| TargetHeatingCoolingMode | String | Target heating cooling mode (OFF, AUTO, HEAT, COOL). for mapping see homekit settings above. | ||
| Name | String | Name of the thermostat | ||
| CoolingThresholdTemperature | Number | Maximum temperature that must be reached before cooling is turned on. min/max/step can configured at item level, e.g. minValue=10.5, maxValue=50, step=2] | ||
| HeatingThresholdTemperature | Number | Minimum temperature that must be reached before heating is turned on. min/max/step can configured at item level, e.g. minValue=10.5, maxValue=50, step=2] | ||
| RelativeHumidity | Number | Relative humidity in % between 0 and 100. | ||
| HeaterCooler | Heater or/and cooler device | |||
| CurrentHeaterCoolerState | String | Current heater/cooler mode (INACTIVE, IDLE, HEATING, COOLING). Mapping can be redefined at item level, e.g. [HEATING="HEAT", COOLING="COOL"] | ||
| TargetHeaterCoolerState | String | Target heater/cooler mode (AUTO, HEAT, COOL). Mapping can be redefined at item level, e.g. [AUTO="AUTOMATIC"] | ||
| Name | String | Name of the heater/cooler | ||
| RotationSpeed | Number | Fan rotation speed in % (1-100) | ||
| LockControl | Number, Switch | Status of physical control lock. values: 0/OFF=CONTROL LOCK DISABLED, 1/ON=CONTROL LOCK ENABLED | ||
| Lock | A Lock Mechanism. with flag [inverted=true] the default mapping to switch ON/OFF can be inverted. | |||
| LockCurrentState | Switch, Number | Current state of lock mechanism (1/ON=SECURED, 0/OFF=UNSECURED, 2=JAMMED, 3=UNKNOWN) | ||
| LockTargetState | Switch | Target state of lock mechanism (ON=SECURED, OFF=UNSECURED) | ||
| Name | String | Name of the lock | ||
| Valve | Valve. additional configuration: homekitValveType = ["Generic", "Irrigation", "Shower", "Faucet"] | |||
| InUseStatus | Switch, Dimmer | Indicates whether fluid flowing through the valve. A value of "ON"/"OPEN" indicates that fluid is flowing. | ||
| Duration | Number | Defines how long a valve should be set to ʼIn Useʼ in second. You can define the default duration via configuration homekitDefaultDuration = | ||
| RemainingDuration | Number | Describes the remaining duration on the accessory. the remaining duration increases/decreases from the accessoryʼs usual countdown. i.e. changes from 90 to 80 in a second. | ||
| Name | String | Name of the valve | ||
| FaultStatus | Switch, Contact | Accessory fault status. "ON"/"OPEN" value indicates that the accessory has experienced a fault that may be interfering with its intended functionality. A value of "OFF"/"CLOSED" indicates that there is no fault. | ||
| Faucet | Faucet or shower. It should be used in combination with Valve or/and HeaterCooler. | |||
| Active | Switch, Contact, Dimmer | Accessory current working status. A value of "ON"/"OPEN" indicates faucet/shower is open. | ||
| Name | String | Name of the Faucet | ||
| SecuritySystem | Security system. | |||
| CurrentSecuritySystemState | String | Current state of the security system. STAY_ARM / AWAY_ARM / NIGHT_ARM / DISARMED / TRIGGERED. Mapping can be redefined at item level, e.g. [AWAY_ARM="AWAY", NIGHT_ARM="NIGHT" ] | ||
| TargetSecuritySystemState | String | Requested state of the security system. STAY_ARM / AWAY_ARM / NIGHT_ARM / DISARM. While the requested state is not DISARM, and the current state is DISARMED, HomeKit will display "Arming...", for example during an exit delay. Mapping can be redefined at item level, e.g. [AWAY_ARM="AWAY", NIGHT_ARM="NIGHT" ] | ||
| Name | String | Name of the security system | ||
| FaultStatus | Switch, Contact | accessory fault status. "ON"/"OPEN" value indicates that the accessory has experienced a fault that may be interfering with its intended functionality. A value of "OFF"/"CLOSED" indicates that there is no fault. | ||
| TamperedStatus | Switch, Contact | accessory tampered status. A status of "ON"/"OPEN" indicates that the accessory has been tampered with. Value should return to "OFF"/"CLOSED" when the accessory has been reset to a non-tampered state. | ||
| GarageDoorOpener | A garage door opener. | |||
| ObstructionStatus | Switch | Current status of obstruction sensor. ON-obstruction detected, OFF - no obstruction | ||
| CurrentDoorState | String | Current door state. Possible values: OPEN, OPENING, CLOSED, CLOSING, STOPPED | ||
| TargetDoorState | Switch, String | Target door state. ON/"OPEN" = open door, OFF/"CLOSED" = closed door | ||
| Name | String | Name of the garage door | ||
| LockCurrentState | Switch | current states of lock mechanism (OFF=SECURED, ON=UNSECURED) | ||
| LockTargetState | Switch | target states of lock mechanism (OFF=SECURED, ON=UNSECURED) | ||
| Battery | Accessory with battery. Battery can be chargeable (configuration chargeable:true) and non-chargeable (configuration chargeable:false) | |||
| BatteryLevel | Number | Battery level 0% to 100% | ||
| BatteryLowStatus | Switch, Contact, Number | Battery low indicator. ON/OPEN = battery level is low; for number if the value is below the lowThreshold, then it is low. Default is 20. | ||
| BatteryChargingState | Switch, Contact, Dimmer | Mandatory only for chargeable battery. ON/OPEN = battery is charging | ||
| Name | String | Name of the battery accessory | ||
| Filter | Accessory with filter maintenance indicator | |||
| FilterChangeIndication | Switch, Contact, Dimmer | Filter change indicator. ON/OPEN = filter change is required. | ||
| FilterLifeLevel | Number | Current filter life level. 0% to 100% | ||
| FilterResetIndication | Switch | Send "filter reset" action triggered by user in iOS home app to openHAB ("ON" = reset requested by user). | ||
| Name | String | Name of the filter accessory | ||
| Microphone | Microphone accessory | |||
| Mute | Switch, Contact, Dimmer | Mute indication. ON/OPEN = microphone is muted | ||
| Name | String | Name of the microphone accessory | ||
| Volume | Number | Microphone volume from 0% to 100% | ||
| Speaker | Speaker accessory | |||
| Mute | Switch, Contact, Dimmer | Mute indication. ON/OPEN = speaker is muted | ||
| Name | String | Name of the speaker accessory | ||
| Volume | Number | Speaker volume from 0% to 100% | ||
| Active | Switch, Contact | Working status | ||
| SmartSpeaker | Smart speaker accessory with Play/Stop/Pause control | |||
| CurrentMediaState | String | Current smart speaker state. possible values (STOP,PLAY,PAUSE,UNKNOWN). Custom mapping can be defined at item level, e.g. [STOP="STOPPED", PLAY="PLAYING"] | ||
| TargetMediaState | String | Target smart speaker state. possible values (STOP,PLAY,PAUSE). Custom mapping can be defined at item level, e.g. [STOP="STOPPED", PLAY="PLAYING"] | ||
| Mute | Switch, Contact | Mute indication. ON/OPEN = speaker is muted | ||
| ConfiguredName | String | Name of the speaker accessory configured in iOS home app. User can rename speaker in iOS home app and this characteristic can be used to reflect change in openHAB and sync name changes from openHAB to home app. | ||
Number temperature_sensor "Temperature Sensor [%.1f °C]" {homekit="TemperatureSensor" [minValue=10.5, maxValue=27] }
Number thermostat_current_temp "Thermostat Current Temp [%.1f °C]" (gThermostat) {homekit="Thermostat.CurrentTemperature" [minValue=0, maxValue=40]}
Number thermostat_target_temp "Thermostat Target Temp[%.1f °C]" (gThermostat) {homekit="Thermostat.TargetTemperature" [minValue=10.5, maxValue=27]}
Number cooler_current_temp "Cooler Current Temp [%.1f °C]" (gCooler) {homekit="CurrentTemperature"}
Number cooler_cool_thrs "Cooler Cool Threshold Temp [%.1f °C]" (gCooler) {homekit="CoolingThresholdTemperature" [minValue=10.5, maxValue=50]}
Number cooler_heat_thrs "Cooler Heat Threshold Temp [%.1f °C]" (gCooler) {homekit="HeatingThresholdTemperature" [minValue=0.5, maxValue=20]}
# Multiple Instances
Homekit has a limitation of 150 accessories per bridge.
The bridge itself counts as an accessory, so in practice it's 149.
In order to overcome this limitation, you can instruct OpenHAB to expose multiple bridges to Homekit, and then manually assign specific accessories to different instances.
You will need to manually add each additional bridge in the Home app, since the QR Code in settings will only be for the primary bridge; however the same PIN is still used.
In order to assign a particular accessory to a different bridge, set the instance metadata parameter:
Switch kitchen_light {homekit="Lighting" [instance=2]}
Note that instances are numbered starting at 1. If you reference an instance that doesn't exist, then that accessory won't be exposed on any bridge.
For complex items, only the root group needs to be tagged for the specific instance:
Group gSecuritySystem "Security System Group" {homekit="SecuritySystem" [instance=2]}
# Additional Notes
# Console commands
# openHAB is not listed in home app
if you don't see openHAB in the home app, probably multicast DNS (mDNS) traffic is not routed correctly from openHAB to home app device or openHAB is already in paired state. You can verify this with Discovery DNS iOS app (opens new window) as follow:
- start discovery app
- find
_hap._tcpin the list of service types - if you don't find _hap._tcp on the list, probably the traffic is blocked.
networkInterfacesettings - verify the flag "sf".
openhab:homekit clearPairingscommand in karaf console.
- if you see openHAB bridge and sf is equal 1 but you dont see openHAB in home app, probably you home app still think it is already paired with openHAB. remove your home from home app and restart iOS device.
